TwinTurbo.NET: Nissan 300ZX forum - When I did mine, needed to use a Dremel conical shaped
jzack
on August 03, 2018 at 6:09 PM
My AC compressor needs to be replaced. I'm thinking
posted by 240Z FeO2
on August 03, 2018 at 10:43 AM
grinding bit to shave the case a bit so the crows foot could work the bolt. That was the most annoying part - since it took a little time.
240Z FeO2
10:43:53 08/03/18
My experience from replacing
Barry(TN)
14:12:27 08/03/18
When I did mine, needed to use a Dremel conical shaped -
jzack
18:09:09 08/03/18
Re: My AC compressor needs to be replaced. I'm thinking
Zxpress
13:24:09 08/04/18
Remove the rear bolt first
Woody75 (Denver)
09:01:15 08/06/18
What are you going to be replacing it with?
ZXoltan
10:25:23 08/06/18
Pricey, but just planning on going with OEM. (n/m)
240Z FeO2
10:37:51 08/06/18
Air Parts in Ocala, FL or eBay
SkiFly01
15:07:22 08/08/18
What did they replace? Just front seal or more?
ZXoltan
07:27:18 08/09/18
It was a seal kit for the case, front half and back half.
SkiFly01
09:54:52 08/09/18
Also, I went back with 2 more cores and swapped out.
SkiFly01
10:17:25 08/09/18
Wanted to followup on my success with the crowfoot.
240Z FeO2
16:17:01 08/09/18
Excellent info. Did you unbolt the hoses before or after
ZXoltan
16:54:14 08/09/18
Before. With the nuts off I could barely raise the hoses
240Z FeO2
17:55:15 08/10/18
I've always used the style on the right. Works for me. (n/m)
Woody75 (Denver)
09:05:23 08/10/18
Interesting. I tried two of the smaller variety of CF.
240Z FeO2
11:53:25 08/10/18
